Help with Sweep
Chante_de_VilliersChante_de_Villiers Member Posts: 2
Hi, I'm new to Onshape and a little confused on how I can achieve the geometry of a bag. I've attached pictures of my process and the resultant sweep preview, which fails and says "result of sweep intersects itself". Any help would be appreciated!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    Those curves are a good start. Maybe loft 1/4 of the bag? Do you mind sharing the doc?
  • MDesignMDesign Member Posts: 1,337 PRO
    Quick unrealistic way is like Matt said. change your sketches to be half the bag. Then loft 1/4 of it with a guide curve. mirror twice or polar array once with 4 instances. More realistic way with non symmetrical geometry a series of planes and sketches with surfacing tools.
