Issues with mating in assemblies
DrewDrew Member Posts: 7
We've been working on a few different projects with some decently complex mating. Something we've noticed is that when adding mates to a component that we've put into our assembly breaks other mates, even though we've already added that same component with the same mates in the same way on that assembly. For example, we're working on something similar to a variable piston pump with a swashplate and when adding the pistons/rod assembly some will work, others will break the system.
Is there something I'm doing wrong? Is this a common issue?
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    Most likely there's an overconstrained chain of mates.
    These may or may not work depending on the underlying tolerances of the parts/mates etc.
    sometimes the mates in a subassembly allow two different solutions and when inserting it in a parent assembly, it can jump into the wrong one. thats very annoying.
    this thread shows an example of an overconstraint failing on tolerances
    If you want more specific help, you could share your document or some pictures. that would make it easier for us to see what could be going on.
