Lamborghini Diablo‬ Sv ‪Frame.
kyriakos_tryfonidiskyriakos_tryfonidis Member Posts: 9 ✭✭
edited February 2016 in Using Onshape
Greetings everyone! I just finished my second project, here some pictures :
I found it hard doing it at onshape, i had to make so many planes to be able to connect through the floors (lower floor, mid top). Most difficult was to connect pipes in an angle to have a perfect fit.
Anyways, it was really a nice challenge i had to think so many work-arrounds and in the end i think i became a better designer because i clearly understood how planes work.
I am extremely happy with the result :smiley:
*ps: if u see something wierd that doesn't look correct it's probably because of the point of view the picture was taken. Everything looks fine to me at onshape enviroment.
  • øyvind_kaurstadøyvind_kaurstad Member Posts: 234 ✭✭✭
    Good job! Must have taken quite some time.
    How many features does the model have? I've found that with large models, things tend to slow down quite a bit.
    Never mind, I see you made the model public.443 features(!). That is a substantial amount.
    I suppose you wrote few requests for 3d sketches while modeling this..
    Does your v12 twin turbo fit to this frame?
    Now I really do hope that you have time to push this project all the way to complete super car.
    //rami
  • shashank_aaryashashank_aarya Member Posts: 265 ✭✭✭
    Excellent! Good job!
  • philip_thomasphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
    This is excellent work. Thank you for making this public - this helps us understand what users are trying to do and what methodologies they use to solve problems. Well done.
    Philip Thomas - Onshape
  • kyriakos_tryfonidiskyriakos_tryfonidis Member Posts: 9 ✭✭
    edited April 2016
    Thank you all of you! I found it hard to do it without weldments. But result is kinda the same, with the exception of the slow pc and huge file  ;)
  • scott_goodwin566scott_goodwin566 Member Posts: 2
    Hi Mate, do you have a link to this file please?
