Can a plane be draped over a 3D object?
jon_smirl
Member Posts: 15 ✭✭✭✭
I'm designing a plastic font panel with various flat regions of slightly different heights and shapes. I'd like to connect these areas with a smoothly curving 3D surface. I'm basically looking for the effect you get from placing a cloth over various objects on a table. The cloth will conform with the tops of the objects and then drape in between them. Loft is sort of what I want, but this seems too complex for loft.
For example - create a rectangle. Place some cylinders and cubes on the rectangle. Now drape a plane over this with it closing against the four sides of the rectangle. Even better would be if I can push or tug on the drapes between the objects to make them look better. Then suppress the objects and create a shell or thicken. Poke holes where the top of the objects were. That's the part I'm trying to make.
NeilCooke
Moderator, Onshape Employees Posts: 5,991
Hi Jon - you can't really do this in a parametric CAD package, you may need to look at a mesh modeler. Having said that if you could share an image or sketch it might be easier to come up with a solution.
Senior Director, Technical Services, EMEA5
