Speed, this tool has not
2»
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    If you are using a VPN you can turn on split tunneling, that should separate your local internet traffic from using the VPN's bandwidth.
    If you're using windows10 then you can turn on split tunneling by right clicking the start button and opening PowerShell (Admin)
    then type the command
    you can check to see if it worked by running trace route and make sure your first hop is the same ip address as your default gateway on your local network,
     you can check your default gateway by running ipconfig
  • LKRENZLERLKRENZLER Member Posts: 30 ✭✭
    @tim_hess427 No we're not using a VPN.  Everyone is currently using their own ISP.  No improvement.  I really don't think this is all network, I think it's slow servers and slow single threaded code.
    Thanks for all the VPN info John, unfortunately that's not the issue in this case.  Great info though.
