Is there a way of changing a variable value for copies of a part?
olivier_ba
Member Posts: 1 ✭
I have a part made from a sketch which dimensions are defined by variables.
I would like to make copies of this part but be able to change the some dimensions only for those copies.
I tried to change the variables values before the copy (transform) of my part, but those new values are not reapplied to my copies.
Is there a way of doing such a thing?
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
You are asking for configurations, if you wan't to file improvement ticket.
Workaround would be duplicating that part studio with different names so you can easily control variable values (disadvantage is that you need to update possible changes to each)
If you need all those parts in same part studio, create new ps and use derive to bring them in.//rami5 -
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,253
We will release feature pattern soon and that will provide another way of accomplishing this.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
Explanation will be help to give correct solution.
