"Onshape" button in Maxwell Render?
lowjack
Member Posts: 14 ✭✭
So I've downloaded Maxwell Render and tried following the steps in the Feb 3 blog post "Introducing Onshape for Maxwell Render." But the problem is that I see no "Onshape" button in the studio anywhere. I can't find anything that would let me use Maxwell with Onshape at all.
What am I missing? My window is labeled "Maxwell Render - x64" and does not look like the screens shown in the blog post. I'm running Windows 7, 64-bit. Any ideas would be most appreciated.
michał_1
Member, Developers Posts: 215 ✭✭✭
You should have also that file "maxwell_onshape_connection_win64.exe", run it and On button will appear.1 -
michał_1
No quite, Studio is where you are setting all scens, then when you'll hit "render" Studio will launch Render, you can also open ready scens directly in Render. At least that how I understand that.5
projektowanieproduktow.wordpress.com
