"Onshape" button in Maxwell Render?
lowjack
Member Posts: 14 ✭✭
So I've downloaded Maxwell Render and tried following the steps in the Feb 3 blog post "Introducing Onshape for Maxwell Render." But the problem is that I see no "Onshape" button in the studio anywhere. I can't find anything that would let me use Maxwell with Onshape at all.
What am I missing? My window is labeled "Maxwell Render - x64" and does not look like the screens shown in the blog post. I'm running Windows 7, 64-bit. Any ideas would be most appreciated.
Optionsmichał_1 Member, Developers Posts: 214 ✭✭✭You should have also that file "maxwell_onshape_connection_win64.exe", run it and On button will appear.1
Optionsmichał_1 Member, Developers Posts: 214 ✭✭✭No quite, Studio is where you are setting all scens, then when you'll hit "render" Studio will launch Render, you can also open ready scens directly in Render. At least that how I understand that.5
projektowanieproduktow.wordpress.com
