How to remove extrude/shell without overhang
edward_sinclairedward_sinclair Member Posts: 4 EDU
Hi, I would like to shell this part in one direction or extrude remove up to the opposing surfaces with an offset. Is there a way to do this easy or any other methods/approaches I should be using to achieve this? The problem I am having is I cant work out a way to hollow out the selected faces without breaking through the opposing side.
Thanks.
  • S1monS1mon Member Posts: 4,064 PRO
    Split the part into two parts. Shell each part, and boolean add them back together.
  • bladecbladec Member Posts: 26 ✭✭
    Here is how you can do it that way. You create a sketch and create an offset of the face with amount you want to shell by and then do a remove extrude up to next with an offset distance.
    https://cad.onshape.com/documents/8424e3ad6e015dd02e4a0118/v/47333a217ba0becc7cf544d2/e/279d66c78d967ff867284ba0
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    @bladec I didn't realize that "Up to next" would work that way! In fact, I've never found an "up to next" that worked for me, so I always use other workflows.
    You really DO learn something new every day.
  • edward_sinclairedward_sinclair Member Posts: 4 EDU
    @bladec You are an absolute legend. Thank you so much.
    I have tried this a couple times before, but for some reason it never worked the way I expected. I thought it wasn't possible, couldn't be done. But today, I can see the light of a new dawn.
