Am I correct that the minimum price for Render Studio is $2500/yr?
joshtargojoshtargo Member Posts: 462 EDU
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    That is the price of Onshape Professional, so yes.
  • S1monS1mon Member Posts: 3,854 PRO
    From an .edu perspective, it looks like Keyshot is much cheaper. Onshape Pro includes other features, but if that’s the only thing that you want…
    https://keyshotsoftware.com/keyshot/education-pricing/
  • martin_kopplowmartin_kopplow Member Posts: 1,150 PRO
    And Keyshot can do a better job at setting up and creating a nice rendering much faster. But I like the idea of Render Studio referencing the same data I work on. So, depending on what is needed and how often, both might have their point: If I only had to do renderings of the final design once, I'd chose Keyshot. If I'd have to render proposed variants and configs frequently as the project evolves, I'd go with Render Studio. If you're on a commercial license anyway, it is only be the difference from the Standard to Pro plan, and that's currently $1000/yr.
  • joshtargojoshtargo Member Posts: 462 EDU
    That works with Sketchup too, so maybe that is the way…
