How to re-order columns in configuration tables?
nicholas_witham
Member Posts: 17 ✭✭
Hi, ultimately I would like to be able to rename columns in configuration tables, but I know that is not possible right now.
Is it possible to re-order the way columns are displayed in a configuration table? You can see below that the upper tables don't match the lower tables. No matter what order I select them in, the columns always end up in this order. Does it have something to do with the order those dimensions were placed?
I've created an improvement request here.
Feature request: Configuration panels and tables — Onshape
Please give it a +1
Yes, it is based on feature order and for sketch dimensions, creation order.
