Combining Mate Connectors
I have a slider that I want to be able to rotate 90 degrees down when the slider reaches the end of its travel. I can't figure out how to both make it slide along the proper slot, then rotate it once at the end of its throw. Either the slider works, or the rotate, but not both. Ideas? Thanks!
https://cad.onshape.com/documents/b5c7090bce2e8814979857ab/w/33b1e2c3c4c2399835359a8b/e/ed2a8f0d7242051885a21304
