New Custom Feature: Animate
NeilCooke
edited November 2024 in FeatureScript
Onshape's Animate feature can only animate one mate at a time. Adding gear relations between mates can make animations more interesting, but if you need an animation showing a sequence of events, then there is no easy way to achieve this other than using the amazing (but manual) technique developed by @john_mcclary
This custom feature expands on John's method and adds a level of automation. Below is a tutorial video showing all the steps to animate a UR Cobot, from building the animation timeline to adding the relevant gear relations in the assembly. Apologies for the length of the video, but it does go into a lot of detail. Please leave any comments or suggestions below.
Animate - Custom Feature:Β https://cad.onshape.com/documents/8afc165187d023c4d83554ff
https://onshape.wistia.com/medias/05cp9kvlxv?embedType=async&seo=true&videoFoam=true&videoWidth=1280
    S1mon Member Posts: 4,616 PRO
    I have to agree with @ben_partouch , this is both amazing and clearly needs to be a real piece of functionality. This is much better than nothing, but anyone doing animation is going to want to be able to drag break points around on a timeline much more graphically. It's nice to be able to control things in real physical values (e.g. m/s and m^2/s), but visually controlling things is often preferred. Being able to drag the assembly directly and record a position and then have Onshape animate between those positions would be a much more typical approach.
    I'm also surprised that the ease-in ease-out is only rounded for linear motion. It's probably good enough for basic animation, but if you look at 3D animation tools or motion graphic tools, there are typically a large number of ease-in/out options.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,959 PRO
    Thanks for this feature Neil! Looks like you put a lot of work into it.
    RENDERCADΒ - Photorealistic product rendering.
    β–šβ–žβ–šβ–žβ–šβ–žβ–šβ–žβ–š
  • billyzelsnack
    billyzelsnack Member Posts: 96 PRO
    This is insane. Both definitions. I love/hate it so much.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,095 PRO
    Neil, this is really amazing! Your features are always so thorough. Clever how you're making the first feature UI look different from subsequent ones.
    @jan_bouwman although I wrote this for a customer, your original post inspired me to get this done!
  • MDesign
    Wow! speechless. That's amazing. Bravo!!
  • jan_bouwman
    jan_bouwman Member Posts: 17 EDU
    @NeilCooke
    Nice to know.. You’re welcome πŸ˜€
  • MichaelPascoe
    Btw, the voice clone is getting better! Doesn't feel like the real Neil, but it is pretty good.
    @MichaelPascoe haha actually that is me, but it was done in a rush.
  • MichaelPascoe
    What!?? 🀣
    The clipping threw me for a loop. I would have bet and lost money on that.
  • EvanReese
    @jan_bouwman That animation is in Onshape?! 🀯 great job
  • jelte_steur_info
    Beautiful application of FS.
  • STEG
    STEG Member, User Group Leader Posts: 141 PRO
    Wow! What a great feature! πŸ‘
    Also the kind of thing that makes me feel dumb by the way… πŸ€ͺ
  • jan_bouwman
    @EvanReese yes, these animations are all in Onshape and run β€˜real time’. No video editing other than some trimming. :-)
    Great fun to make, however time consuming.
  • gerry_friedman
    gerry_friedman Member Posts: 3 ✭✭
    I've been working with this custom feature for a while now on a number of animations.
    Don't know what the issue is but some of the motions are not smooth (have hiccups I call it) and speeds are not consistent (speed up or slow down).
    In doing a presentation I've put my model into the "perspective view" and really see these issues show up more. May be upload and download speeds have something to do with this. Any suggestions? (also running on a late 2013 iMac)
    I'd like to suggest in preparing a timeline, it would be nice to be able to "insert a step" and have subsequent steps shift. This would avoid having to rewrite everything.
    I've also found the animation step limitation to be 3600 which affects speed. Could use a larger number to slow long motions down. (I've got hundreds of feet of travel in some models.)
    Otherwise, thumbs up for this feature.
  • Ste_Wilson
    Ste_Wilson Member Posts: 687 EDU
    That is a thing of wonder! Fantastic.
  • MichaelPascoe
    edited October 2025
    Found a new way to animate along a path forcing a "physics" friction glitch.
    There is 1 big limitation currently and that is you can't animate a revolute mate beyond 36000 degrees.
    A fix for this would be to have a true unlimited rotation animation option for things like revolute mates. Or another could be to turn off position reset on the continuous loop mode, this way it simply resets the chosen mate instead of resetting the position of everything.
    https://cad.onshape.com/documents/696186437e41d7bae241f696/w/1dc8c4655d274989ef539937/e/bb157eba631d7…
