Adding Configuration to BOM Table
PattabiPattabi Member Posts: 54 ✭✭
Hi Everyone!
I’m working on a part in Onshape where I have a variable input for an extrude length defined in the Part Studio. I would like to specify this length in the assembly and have it automatically appear in the BOM table. My goal is to avoid having to create a drawing just to check the length of the extrude.
Does anyone know how I can add the length of the extrude as a configuration value or custom property so that it shows up in the BOM table directly? Any help or tips would be much appreciated!
Thanks in advance!
  • jelte_steur_infojelte_steur_info Member Posts: 653 PRO
    you could use the Partname custom feature, and include the length in the partname:
    https://cad.onshape.com/documents/f4d470584fdeef9603415532/v/7d0c0b30a8b73bbd6ed13b01/e/acddbbed81af3772a07adf21
  • PattabiPattabi Member Posts: 54 ✭✭
    Thanks for the suggestion!
    I intend to define the length at the Assembly level, not at the Part Studio level, because the aluminum extrude can be used in different sizes at the Assembly level, which I cannot know when creating it at the Part Studio. Otherwise, every time I need a different size, I would have to create a new configuration in the Part Studio, which I want to eliminate.
    When defining the length at the assembly level, you'll be able to call in a configurable part studio (unlimited options if you use a configuration variable for the length). It will change the length, as well as the partname in one go since it will apply the variable to all features in the tree, not just the geometry.
    rightclick to 'convert to expression' on the sting/text field and input your configuration variable there. using toSring(#variable)…
    in the example you'll see I used toString(#Length/millimeter) (to make it unitless), and then added the units in the third string.
    @EvanReese: is there a way to make a units option in the feature? so that it'll do that for you for all 'ValueWithUnit' types?
    https://cad.onshape.com/documents/c440134b177eb7d0461c0b2b/w/d9e444e9085393c16f067af4/e/2f121e3a43ec7d0196864cd8
    see below the assembly on the right (BOM showing) and configurable part studio on the left.
    @jelte_steur814 Thanks for the detailed explanation.
    The concept you explained would not work if I wanted to have this many times in Assembly with different sizes. Below is an example of what I am looking for.
    I have a Square Profile at the Part studio as a Purchase part now I want to use the part in an assembly with different sizes like 500 and 200 mm, and now how can I communicate the length through BOM? See the below images. I wanted to have the same Part Number and Name for both the parts.
    if you insist on using a single part number for different length parts, be my guest.
    there are 2 ways to approach this:
    If you rock a pro or enterprise license, you could create a custom property, add it to the BOM and configure that in a similar custom feature as partname, but then adapted to configure the length.
    else try and hack the partname feature to configure the description.
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    edited March 2025
    RENDERCAD
    @MichaelPascoe Thanks, Micheal! This is exactly what I am looking for. Can you also please share the "Add to string" Feature script, it's not available online!
    edited March 2025
    Shared! Add to string
    Joining strings (text) within the part studio:
    For anyone else needing to add to strings within the part studio. You don't actually need a custom feature for this:
    You can join strings together with the tilde symbol (~) like this directly within an input field: "myPrefix_" ~ "OriginalString" ~ "_Suffix"
    This concatenation of strings will result in this: "myPrefix_OriginalString_Suffix"
    You can do this with variables if the variable is a string: #myVariable1 ~ "_" ~ #myVariable2
    Also you can convert numbers and values with units to string like this: toString(#myVariable1) ~ toString(#myVariable2)
    RENDERCAD
  • EvanReeseEvanReese Member, Mentor Posts: 2,867 PRO
    The Part Name feature is a bit dated now that "convert to expression" is a thing, and now that you can drag out the feature UI to make it wide so you can have a long expression in there to concatenate the strings easily. I think Michael's Set Property feature is a great way to go here.
    I wish there were a tiny button for "Convert to expression" this way more people would know about it. Or perhaps it would auto convert to expression if it reads a # and then theres instead a right click option for "convert to text"
    RENDERCAD
    edited March 2025
    @Pattabi_Kakumanu You will probably want the Variable to String feature if you are trying to put a measurement into string format. It's a pain to try to round and convert values with units when using in-line featureScript. Since Onshape uses meters behind the scenes, if you try to do toString(38.8 inches) it will turn that into something like " 0.985438438541864354 meters".
    Variable to String - Feature: This will take a value with units and convert it to a readable string. Example: 0.985438438541864354 meters to "38.8 in"
    Really useful when turning a measured value variable into a string.
    https://cad.onshape.com/documents/19dacc01596e7c326bbfb137/w/0567dd7ffac5327836c9bb93/e/cd2c8c665d8a4b00ab3…
    RENDERCAD
    Thank you, everyone!
    I was able to achieve this by utilizing three custom features to bring the configurable variable value into the Name property. This allows anyone reviewing the BOM to easily identify different profile sizes without the need for additional drawings.
    Thank you @MichaelPascoe for the support!
  • kim_nguyen923kim_nguyen923 Member Posts: 6
    Hello, I'm running into this issue right now and hoping to avoid making separate parts. Could you put the steps on how you used the custom features to get this working?
    Could you help lay out how you ended up solving this? Im trying to do this myself now and I can't find the set property feature. Could you also give an example of the inputs for each feature and how it gets added to the BOM
    @kim_nguyen923 Set property's name has changed to Property Attribute thumbnail.png  Property / Attribute feature because it now is capable of getting or setting (properties, attributes, identities, and more)
    Here is the Variable to String feature. For converting measured variables to an expected string value.
    And here is Cutlist+ fefature which will automatically add the profile dimensions, end angles, and length of frame to either the part name or the part description for BOM visibility.
    Also, there is another way to get multi part studios to a bom while handling duplicate parts with Assembly Imposters (Feature + App). It is a bit more work, but ensures the assembly bom properly counts duplicate parts and doesn't show them multiple times in the bom.
    RENDERCAD
    I'm quite confused on how i achieve what Pattabi did using these features you listed
    I imported the Variable to String
    converted my Configuration Variable to a string
    #len = #ConfiguredVariable
    but now i want this value as part of my part name
    so in Pattabi example he has Extrude[45-4545]#len
    his BOM shows each part with the length configured
    Ok, your almost there. Once you have the converted value, use the Property / Attribute feature to set the property (Name) of your part. Right click the name input box and "Convert to expression"; this will let you use your variable within that input box.
    RENDERCAD
    after a lot of head banging, i finally figured it out
    I needed to reset my parts - I had already named everything and was trying to search down how to get this working and the problem was that because i imported the FS after and tried using it on an already named part it doesn't run the script properly
    so hopefully to help the next person who tries to figure out how to set a part name via a configuration variable you need to do the following
    import the 2 FS
    Variable to String & Part Name FS
    first convert your desired variable to a string
    if you've made any changes to your part name you will need to right click your part → properties → reset all
    now that you've reset the properties or you've never changed the name of the part you can now use things like Part Name FS or other FS that make changes to the properties
    Thanks for all your help! I just started using onshape so just learning about some of the gotchas like needing to reset the properties for FS to work.
