Sketch is not contrain
John_VasanthJohn_Vasanth Member Posts: 8 PRO
I tried to dim all sketch but still its showing as not constrain.
  • S1monS1mon Member Posts: 4,091 PRO
    It's very hard to solve this without access to a public document, but…
    I can see that there's something done with offsets. If you've trimmed them, sometimes you're left with stray points which may be coincident with other vertices, but without being properly constrained. I would look carefully at each vertex and see if there's more than one point there.
  • marlon_samulesmarlon_samules Member Posts: 2
    It looks like offsets might be involved. If you’ve trimmed them, you could end up with stray points that overlap with other vertices but aren’t properly constrained. I’d carefully check each vertex to see if multiple points are in the same spot.
  • John_VasanthJohn_Vasanth Member Posts: 8 PRO
    Thank you . the radius on a sketch was duplicated . . . i found and corrected .
  • eugene_fletcher368eugene_fletcher368 Member Posts: 1
    edited July 2025
    It looks like your sketch isn’t fully constrained even though you’ve added dimensions. Make sure to check for missing geometric constraints like coincident, horizontal/vertical, or tangent. Sometimes, lines may not be fully connected or there might be small gaps. Try dragging parts of the sketchif anything moves, it’s still unconstrained. Also, check that everything is anchored to the origin or a reference plane. Hope that helps!
  • tahir_khan250tahir_khan250 Member Posts: 2
    It sounds like your sketch might still be under-defined despite having dimensions. Keep an eye out for missing geometric constraints like perpendicular, tangent, or coincident—those are easy to overlook. Also, try gently dragging parts of the sketch; if anything shifts, it’s a sign there’s still something unconstrained. Make sure your base geometry is fixed to the origin or a known reference point. That usually helps lock everything down properly.
  • alen_crickalen_crick Member Posts: 4
    That’s a common issue, especially when working with more complex sketches. Sometimes it helps to use the “Show constraints” option to spot anything missing, and then add dimensions or constraints one by one until everything turns fully defined. Keeping the sketch simple and building up gradually can also prevent it from becoming under-constrained.
    It’s also worth checking if any overlapping lines or duplicate geometry are causing the sketch to stay under-constrained. Sometimes deleting and re-drawing the problem area can resolve it faster than hunting for the missing constraint. Keeping constraints organized from the start makes troubleshooting much easier later on.
  • muneeba_saeedmuneeba_saeed Member Posts: 2
    it looks like you’ve added dimensions, but the sketch is still under-defined. This can sometimes happen if there are missing geometric constraints like coincident, horizontal/vertical, or tangent relations. Try checking if any lines or points are still “blue” instead of “black” — that means they aren’t fully constrained yet. Also, make sure you don’t have overlapping or duplicate entities, since that can prevent the sketch from locking down properly
    It sounds like the issue might be related to missing constraints or overlapping geometry. Double-check if all lines are fully defined, and try using “Fix or “Coincident” constraints where needed. Sometimes even a small gap can prevent a sketch from being fully constrained.
  • james_vince01james_vince01 Member Posts: 2
    Looks like the issue stems from offset trimming leaving behind duplicate or nearly coincident vertices that aren’t constrained. Inspect each vertex for unintended duplicates, merge/weld any overlapping points, and reapply proper constraints. Also run a cleanup (remove doubles / snap vertices) and re-check edge/face connectivity.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,097 PRO
    @lougallo
    Admins…. I think these might all be fake accounts using chatgpt to answer and/or copy paste…
  • henry76t_jameshenry76t_james Member Posts: 2
    It seems the problem could be due to incomplete constraints or sketch elements overlapping. Make sure every line and point is properly defined, and consider applying “Coincident” or “Fix” constraints where necessary. Even tiny gaps or misalignments can stop the sketch from being fully constrained.
