in the assembly, the gear ratio doesn't seem to be working.
the gear ratio is the driving gear teeth divided by the driven gear teeth, right? my problem is that when i put in, say 0.5, it seems to take it as 5. any help appreciated! thank you!
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,004 PRO
    Depends on the order you select the two revolute mates. It could be driving/driven or driven/driving. In your case, it could be 1/2 or 2/1. If your share your document, I'm sure someone will be able to check.
  • Matt_Shields
  • ethanbob_makeit
    ethanbob_makeit Member Posts: 5 ✭
    Thanks!!!
