⚠️How to Simulate Assembly Rail Collisions
MichaelPascoe
Member Posts: 2,732 PRO
There's probably a tech tip or post on this, but I thought I would share anyways.
You can simulate collisions on a rail with dynamic limits by:
Linear Rail
- Have each rail object start at the end of the next rail object.
- Limit their slider mates to a slide min of 0.
- Place one parallel (Or another slider?) mate at the end of the last rail object to the end of the rail with a min or max z limit (it depends on the direction of the mates).
Alternatively, instead of a min slider limit where they all reference each other, you could probably have 2 parallel mates per end of a rail object, but this would take more time to set up.
7
Circular Rail
What about a straight into a curve? I wanna simulate my garage doors
Derek Van Allen | Engineering Consultant | Meddler@Derek_Van_Allen_BD For a garage doors, you won't need collision detection, just a chain of revolute mates and tangent mates.
I learned this technique from @NeilCooke I believe.
Animate Garage Door
Make sure the top edge extends well beyond the rail so that the helper parts have something to travel on.
Here is where you could add the collision technique if you want, but not really required since I know it's ~10ft.
https://cad.onshape.com/documents/62fe036f7adf211619a6b478/w/9616e65987871ef989e3f83c/e/82402961e4bba1…
