What do I need to do to fix my sweep that comes up red?
t_y450t_y450 Member Posts: 6
I have a sweep, and OnShape tells me it can not generate geometry, but i see a bunch of red highlighted geometry that looks correct. Is there any way to fix my geometry to make this sweep work?
Here is the sweep I am trying to do. And a document link is bellow:
https://cad.onshape.com/documents/e43583b6a7008c7d7aa70317/v/55d1363e597d81ad04d876b8/e/fbf64c68e2de00babd32b785?renderMode=0&uiState=680fbd5d8e44493bee8a5abd
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 385 image
    The sweep path you are choosing has non-tangent joins between entities. I think it's going to have a very hard time following this and at the same time dealing with the lock direction you have specified. Can you do something a bit smoother with those curves you are extracting from Sketches 30, 31 etc?
  • t_y450t_y450 Member Posts: 6
    Yes, I managed to get it to work useing multiple sweeps and a loft. Thank you for your help, and so while I was unable to solve this sweep itself i still got the result I needed. Do i mark this as a solution?
