Noob needs help, creating a slight countor /curve
aaron_widgeraaron_widger Member Posts: 6
Hi all :)
This is my first model ive made, and I am sure i have done some things wrong and more than open to help. My idea is to 3d test print this and then keep building from here.
one thing im struggling with is I want to add a slight contour or curve to this to match the slight shape a bonnet would have (this is a bonnet vent)
Could anyone help here! tried lots of youtube searching but not sure what or how to go about it.
https://cad.onshape.com/documents/29431958fef3d0f18f0b86c4/w/b8400e8ebbf1157839592f8b/e/c9be1feb539e808a79a7e918?renderMode=0&uiState=681fdfadde079c2e7261e4fd
thanks so much
  • MDesignMDesign Member Posts: 1,277 PRO
    You can't bend an existing flat part. You have to model it bent. Being that it's you've self designated as a noob. I suspect you will be well served by the tutorials at learn.onshape.com. and exploring the limits and capabilities of all the tools at your disposal.
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    edited May 2025
    build the bottom plate according to the contour you'd like with an intersected extrude from the right plane. (is it bent only in one direction?)
    then sweep the coutour over that.
    Then finish with blends at the end.
  • aaron_widgeraaron_widger Member Posts: 6
    Great guys, thanks for your help :)
    thanks, im struggling with this, trying to sketch on different planes etc, im trying to understand where the forums learning will highlight it but havent found just yet.
