Sketch: highlight all control points of an entity and the entity a control point is controlling.
vanowmvanowm Member Posts: 137 ✭✭
Hello.
Please, add ability to highlight all control points of an entity when the entity is clicked/hovered on, and when a control point is clicked - highlight the entity it controls.
For example, currently when you have multiple conics, it becomes unmanageable to figure out which control point belongs to what entity.
Sometimes you move a control point 1 pixel and everything is getting mangled, and you still have no idea which entity you just adjusted.
Highlighting obviously should be different from selection highlighting.
If multiple entities joined at a control point, all entities should be highlighted.
Perhaps this could be done while ALT key is pressed to avoid overwhelming highlighting?
Thank you.
P.S.
By control point, I mean anything that represented by a dot, whether it's a center of circle/arc, spline controls, end of a line, etc
