[Feature Request] - Configurable minimums/maximums for Configuration Variables
Chris_KellyChris_Kelly Member Posts: 8 EDU
edited July 2025 in Product Feedback
It would be nice if I could either directly configure the definition values for a configuration variable or use another configuration variable and expressions inside of them. I find myself wishing this was a thing pretty often when setting up complex configurations, so I can avoid invalid values more easily depending on other values instead of having to do broad limits.
  • Gage_WilkinsonGage_Wilkinson Member Posts: 3 PRO
    I second this request. Have you found any work arounds?
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    Do you have any specific situations or examples? That would help in providing the relevant work-arounds.
    combining array's into a variable comes to mind and is very powerful.
    The model I'm working with right now is not mine to share, but it is essentially one highly configurable thickened surface model of a chair back. The model pretty seamlessly accommodated a huge variety of widths, heights, and other variables. Some applications require a divot in the chair back (shown below). I'd like to use configurable min/max limits on the placement and size of the divot to prevent it from being placed outside the bounds of whatever the chair back's width/height happens to be configured to right then.
  • EvanReeseEvanReese Member, Mentor Posts: 2,852 PRO
    Here's a video I released recently that covers a workaround. Should have another one up today that expands on it.
    Here's one with a better approach. I'd still like to have configurable min/max on configuration variables though
  • phineas_phogphineas_phog Member Posts: 6
    My example is for a text label on my nut and bolt tubs, I have many different labels and I want to set the size maximum of the text within the label so that it doesn't go over the edges. I have many copies of these labels in a project with all different things on them (different sizes etc) I have the nominal size set by a variable in the text so I can just change the variable from 5 to 6 and all the labels change from M5 to M6. But I am experimenting with different fonts and want to get the biggest and clearest text I can within the confines of the label. In the screenshot below the MFW part is what I want to set maximums on. When I change the font or the height of the text some of the labels will no longer fit width wise (width currently unrestrained)
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,581 PRO
    @phineas_phog
    I think this is what you are trying to do?
    This is one way to do it, I used the bounding box FS but you could probably just get away with a measured variable of the text box width to simplify things…
    https://cad.onshape.com/documents/691dc3dfc28f13d9c5f7a6fb/w/b959d623f3efe63dfea46f91/e/5bd3419483a0ece428be1757?configuration=text%3DABC&renderMode=0&tangentEdgeStyle=1&uiState=69a0947bb5ab3fd2d6608bd4
