[Feature Request] - Configurable minimums/maximums for Configuration Variables
Chris_KellyChris_Kelly Member Posts: 8 EDU
edited July 28 in Product Feedback
It would be nice if I could either directly configure the definition values for a configuration variable or use another configuration variable and expressions inside of them. I find myself wishing this was a thing pretty often when setting up complex configurations, so I can avoid invalid values more easily depending on other values instead of having to do broad limits.
  • Gage_WilkinsonGage_Wilkinson Member Posts: 3
    I second this request. Have you found any work arounds?
  • jelte_steur814jelte_steur814 Member Posts: 519 PRO
    Do you have any specific situations or examples? That would help in providing the relevant work-arounds.
    combining array's into a variable comes to mind and is very powerful.
    The model I'm working with right now is not mine to share, but it is essentially one highly configurable thickened surface model of a chair back. The model pretty seamlessly accommodated a huge variety of widths, heights, and other variables. Some applications require a divot in the chair back (shown below). I'd like to use configurable min/max limits on the placement and size of the divot to prevent it from being placed outside the bounds of whatever the chair back's width/height happens to be configured to right then.
  • EvanReeseEvanReese Member, Mentor Posts: 2,546 PRO
    Here's a video I released recently that covers a workaround. Should have another one up today that expands on it.
    Here's one with a better approach. I'd still like to have configurable min/max on configuration variables though
