Enter to confirm is inconsistent.
BenjammannBenjammann Member Posts: 7 PRO
Abandoned SW once I learned the ways of Onshape, but incredibly frustrated at the lack of ability to use the Enter or Esc key to confirm / exit a sketch. So much lost time reaching for the mouse, hunting down and clicking the green check. :/
Not seeing a solution outside of extreme hacking.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,598 PRO
    Yes, it's a bit annoying, although "enter" is used to confirm auto-dimensions so I would probably end up accepting sketches by mistake if it also did that…
    Depending on your workflows, you may not actually have to "accept" as launching a new command "auto-accepts", so if you are going to do an extrude or revolve or whatever, you can just launch that command without accepting the sketch first.
  • _anton_anton Member, Onshape Employees Posts: 525 image
    Indeed, other features can be accepted with enter, but not sketches. For me, it's typically not too painful because the UI interaction is already so mouse-heavy; that said, a shortcut would be nice. Feel free to post an improvement request.
  • BenjammannBenjammann Member Posts: 7 PRO
    edited August 2025
    @eric_pesty Thanks! Agreed. I launch main features from the sketch directly with an Azeron Cyborg II. Unfortunately, 80 percent of my Sketch time is Edit..
    @_anton You've read my mind as I went to reply to eric. A "Confirm Sketch" hotkey would solve this. Bonus points for a "Cancel Sketch" one. SW even had a hotkey to edit the feature or sketch that I clicked on in the graphics window (but I wont push it)
    Ill feature request. Didn't want to jump directly to that without some feedback, but here we are!
    Feature request submitted.
    I find myself wanting this one all the time for sure. Especially so I can Shift+Enter to start a new sketch.
