(Sketch tool) Spiral
It would be really useful to have a Spiral tool in the sketch toolset that would probably be in the arcs dropdown menu. I think it should allow users to select a center point then the beginning point and, end point of the spiral then click and set the amount of walls or rotations.
  • MDesignMDesign Member Posts: 1,339 PRO
    This suggestion from @Derek_Van_Allen_BD doesn't help you in sketch mode but I would imagine would help achieve the same end result. Use the helix tool and specify a start and end point in axis mode.
  • charlie_scott840charlie_scott840 Member Posts: 4
    Okay I get your point but that's just not very convenient being an external tool rather than apart of a sketch😵.
    As they say beauty is in the eye of the beholder. I suspect convenience may be similar and depend on your goal/desired end product. Would be handy in sketch for sure I suppose. I don't do much with spirals though.
