Improvements to Onshape - September 18, 2026
Aaron_Magnin
Aaron_Magnin Member, Onshape Employees Posts: 122 image
edited September 18 in New in Onshape
This release leans into intelligent, parametric design, led by dynamic suppression in Assemblies, alongside a broad set of refinements that smooth out everyday workflows across in-context design, Feature Studios, Drawings, PCB Studio, and Render Studio.
CAD
DYNAMIC SUPPRESSION FOR ASSEMBLIES
Dynamic suppression in Assemblies lets you automatically suppress or unsuppress parts, patterns, and Mates based on other values. This enables more intelligent parametric assemblies that dynamically adapt their structure and behavior as designs change — suppressing a divider when a cabinet drops below a given width, for example, and unsuppressing a pattern and a different Mate scheme when it grows beyond another.
https://onshape.wistia.com/medias/fs3vm8urte
RESET CONFIGURATIONS TO DEFAULT VALUES
The new Reset to default button makes it easy to restore all configuration parameters to their default values with a single click. Available in Part Studios, Assemblies, and Variable Studios, it lets you freely test configurations and quickly return to your preferred baseline.
https://onshape.wistia.com/medias/3zo8ar2919
SIMPLIFIED EDIT IN CONTEXT MENU
The improved Edit in context workflow makes it faster to begin in-context design by taking you directly to the Part Studio when no contexts have yet been created. Clear visual feedback and context-aware menus also make it easier to understand when a context exists and to quickly access existing references.
https://onshape.wistia.com/medias/m869yxnl7w
HIDE IN CONTEXT INSTANCES WITH A HOTKEY
This release introduces the ability to use the same “hide selected part” hotkey used in Part Studios and Assemblies (by default the Y key) to hide instances while editing a context. This makes it easier and faster to focus on your in-context designs.
https://onshape.wistia.com/medias/k8e3ac7eae
CONFIGURABLE SECTION VIEW INTERFERENCE COLOR
The color used to indicate interference, or overlap, in section views is now configurable, letting you pick a color that stands out clearly against your own models and display theme.
https://onshape.wistia.com/medias/tqsem96eov
OPEN DOCUMENT IN A VIEW-ONLY STATE
Onshape now introduces a selectable View only mode, available to users with edit access to documents. This mode, which can be toggled on or off at any time, is a clean way to ensure you don’t accidentally edit the document while reviewing it. Administrators may also enable a setting so that all documents company-wide open in this mode by default.
https://onshape.wistia.com/medias/2as8nkhiyq
FILTER BY WARNINGS IN PART AND INSTANCE LISTS
You can now filter the Parts and Instances list by warnings, making it quicker to locate and resolve problem geometry in large models.
https://onshape.wistia.com/medias/84ne8yzx9j
RETAIN ANALYSIS SELECTIONS WHILE EDITING SKETCH DIMENSIONS
Analysis tool selections now persist while you edit sketch dimensions, so you can change a value and watch the measured result update without having to reselect your geometry each time. This improves on previous behavior: if you did not click outside the box, it would lose the selection.
https://onshape.wistia.com/medias/61sjkwsrr5
GLB GEOMETRY FORMAT FOR URDF EXPORT
Onshape now provides a GLB geometry format option when exporting as URDF. This delivers binary 3D mesh geometry for third-party robot simulation software.
https://onshape.wistia.com/medias/cxfaqt1jmi
FEATURE STUDIO
COMPARE SUPPORT FOR FEATURE STUDIOS
Compare now supports Feature Studios, so you can see exactly what changed between versions and workspaces of your custom feature code without leaving Onshape.
https://onshape.wistia.com/medias/0uta4op3aj
HIGHLIGHT FIND ALL RESULTS IN FEATURE STUDIO
Find All in the Feature Studio editor now highlights 'symbol' and 'text' matches inline, making it much faster to scan where a term appears across your custom feature code.
https://onshape.wistia.com/medias/mfgrzrpitq
COMMIT DROPDOWN MENU IN FEATURE STUDIO
The Commit button in Feature Studios is now a dropdown that gives you the choice of committing just the current Feature Studio tab, or all changed Feature Studio tabs in one action. This reduces the time spent committing multiple changes and the chance that a commit gets missed — particularly useful alongside find-and-replace and refactor/rename, which tend to leave a number of Feature Studios uncommitted.
https://onshape.wistia.com/medias/wvmdoyj13n
DRAWINGS
PARENTHESES FOR SURFACE FINISH SYMBOLS
Onshape now allows you to include parentheses around your surface finish symbols in Drawings. This is useful for indicating a deviation from the global surface finish requirement in the ISO standard.
https://onshape.wistia.com/medias/qhu4rlt29u
PCB STUDIO
IMPORT ALTIUM BOARDS WITH BENDS
Altium boards that include bends can now be imported into Onshape, bringing rigid-flex designs into your mechanical assemblies with their bent geometry intact.
https://onshape.wistia.com/medias/g586tvym4a
BOARD PART FIXED WHEN BUILDING A PCB ASSEMBLY
The board part is now fixed when building a PCB assembly, preventing accidental moves that would otherwise pull your components out of alignment with the board.
https://onshape.wistia.com/medias/uswhf87wok
RENDER STUDIO
LIGHT AIMING
Render Studio now lets you aim a light directly at a point on your model, making it far quicker to set up precise, intentional lighting for a shot. See the Light (Render Studio Advanced) topic for more information.
https://onshape.wistia.com/medias/ryw2tgx8et
RESET THEME AFTER BACKGROUND COLOR CHANGES
A new option restores the theme after you change the background color, so you can experiment freely and return to your starting point in a single click.
https://onshape.wistia.com/medias/kuje4kwrc2
DATA MANAGEMENT & ENTERPRISE
OPEN IN ONSHAPE LINKS IN ANALYTICS
Every analytics dashboard now includes an 'Open in Onshape' link, letting you jump straight from a row in your analytics to the document it describes.
https://onshape.wistia.com/medias/ncs0tvewqq
MOBILE
REDESIGNED SHARE DIALOG AND SHARE PANEL ON iOS
The share dialog and share panel have been reworked on iOS, making it easier to see and manage who has access to a document straight from your iPhone or iPad.
https://onshape.wistia.com/medias/aq39ednxbr
ONSHAPE LABS
AI-GENERATED THUMBNAIL DESCRIPTION SEARCH (PUBLIC DOCUMENTS)
Public document search now matches on AI-generated descriptions of document thumbnails, so you can find a design by how it looks, not what it's called. Available for testing in Onshape Labs.
https://onshape.wistia.com/medias/tiefvyeion
Please take a moment to try out these new features and improvements, and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new documents. Over the next few days, these features will also be available in documents created before this update. Mobile app interface updates are available via the Apple App Store or Google Play Store and are released in the days following the update.
«1
