How to continue a thread
jon_woellhafjon_woellhaf Member Posts: 92 ✭✭✭
In this part,
I can get the thread to start where I want it to, but the thread ends abruptly on the right.
How can I get the thread to continue?
    edited March 2016
    @jon_woellhaf , You can change thread end as per your requirement by changing helix as shown in below video method.
  • jon_woellhafjon_woellhaf Member Posts: 92 ✭✭✭
    Thanks and takk for the good suggestions.
    I found I was able to achieve exactly the result I wanted only by splitting the part 0.1 from the right end, deleting the short piece, and revolving a 60 degree chamfer on both ends. It seems there should be an easier way.
    On second thought, I probably didn't need to do the split. Revolving the 60 degree chamfer would have been sufficient.
