Replacing drawing template/change drawing size
zoltan_szabozoltan_szabo OS Professional Posts: 13 PRO
How can we change size (e.g. A3 -> A2) of an existing drawing sheet or how to replace the whole drawing template (frame& title block) in an existing drawing?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ zoltan_szabo , At this stage Onshape don't have such capability.Hope this will be introduce in feature updates
    @zoltan_szabo , Currently this facility is not available in Onshape. This issue is already recorded by Onshape system. You can vote for improvement request for this by clicking on below link.
    https://forum.onshape.com/discussion/1689/change-drawing-template-on-the-fly
    In near future we hope that this facility will be provided by Onshape.
  • zoltan_szabozoltan_szabo OS Professional Posts: 13 PRO
    ok, thanks, I voted up
  • michael3424michael3424 Member Posts: 756 ✭✭✭✭
    It's probably been said before but the IR system needs it's own improvement.  When accessing an IR, it would be nice to see immediately if you have already voted it up or not.  It also seems unwieldy that one has to click through twice to actually vote up (or down) an IR.
  • fastwayjimfastwayjim Member, OS Professional, Mentor Posts: 220 PRO
    I just added myself to this one. It should be fixed soon, as this is a pretty common mistake, especially for n00bs who are just learning how to create spectacular engineering drawings.
  • jon_mcintyrejon_mcintyre Onshape Employees Posts: 56 image
    We're aware that this is a top issue and are planning it.  If you have preferences on how to auto-position and size views, title block, borders, etc. on the new size of sheet, let us know.
  • julien_mayorjulien_mayor Member Posts: 1
    +1 if you changed your identity you need to be able to update your drawing template easily. thanks
  • michael@redmart.commichael@redmart.com Member Posts: 1
    Is this functionality, to change the drawing  ,still pending?
  • tom_macphailtom_macphail Member Posts: 11 PRO
    Very keen to see this functionality added.
    Would expect the views to maintain position around the centre of the sheet and maintain the same scale.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,042 PRO
    Still waiting for this improvement, please vote here
    https://forum.onshape.com/discussion/6001/change-border-template#latest
