Rotate Parts in a Linear Pattern
ryan_thiessen
Member Posts: 7 ✭
I have the following document that I am working on:
https://cad.onshape.com/documents/18bdd1442a2e9d7f2168aa40/w/0d839adda791d448ab1900b2/e/9651040dcdd84b4474fe93ab
I need to be able to rotate the parts I have created along the helix as I pattern them (or after the fact). Is there a way to do this?
I know a crude way to do it would be to sweep my initial sketch along the helix and then cut out the sections inbetween, but there must be a better way. Although it really wouldn't matter, in this example when looking at a single part on the flat the front and back face would have a slight skew to them.
Also, I need to be able to do it in the parts studio as I still need to punch a square hole down the middle of all of them so that it remains straight as the outside follows the helix.
@ ryan_thiessen, You can rotate the part while creating pattern by the help of variable and feature pattern.
Since i m not able to control the twist of sweep.so it is deviating along the length.
you can look into below link for more info
https://cad.onshape.com/documents/56f126bae4b08ab14ced4841/w/a8f3624b3331998720a39e49/e/db414f14854946aa7926c6ae
5
5 -
Thanks for all your help. This was great!Narayan_K said:@ ryan_thiessen, You can rotate the part while creating pattern by the help of variable and feature pattern.
https://cad.onshape.com/documents/56f126bae4b08ab14ced4841/w/a8f3624b3331998720a39e49/e/db414f14854946aa7926c6ae1 -
This is a nifty trick! I didn't realize you could define and change a variable on the fly in the feature tree. A bit cumbersome for the use case though. Old post so I'm a little surprised Onshape hasn't included a way to combine both rotation and translation in patterns… This seems like pretty standard functionality for patterning features.
1
