can i measure distance between arbitrary points without creating a sketch element?
paul_1paul_1 Member Posts: 33 ✭✭
edited March 2016 in Community Support
sometimes i'l looking at a drawing and am interested in the distance between two points either or both of which might not be part of a defined feature.
is it possible (keyboard shortcut of some sort?) to get the distance between a selected point and the mouse cursor?  this would take care of what i want most of the time.  the distance between two non-feature points would be harder, obviously.
  • fastwayjimfastwayjim Member, OS Professional, Mentor Posts: 220 PRO
    Not that I know of, since measurements are only (automatically) shown once something is selected.
    Can you share a screenshot? Maybe there is another way to get what you need quickly...
  • paul_1paul_1 Member Posts: 33 ✭✭
    okay, thanks.  i don't have a particular screenshot, because i don't have a particular example.  it's just a general wish.  if you were holding a part in your hand, you might pick up a ruler to see roughly how big some feature was.  ("what if i wanted to cover a third of this face -- about how thick would the frobnitz need to be?")  clearly i can do the same by adding and then deleting a point, but i was hoping to just pick dimensions off the screen without doing that.  no big deal.
    why is this marked "answered"?  "not that i know of" is not an answer.   "no" would be an answer.
Howdy, Stranger!
