Improvements to Onshape Mobile (iOS) - February 27, 2015
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
edited February 2015 in Onshape Mobile
Another update was pushed today for Onshape mobile on iOS.  This build has also been updated to be compatible with our subscription plans, which will be coming soon.  This release also focused on  updates to the feature dialog UI, toggles for sketch inferencing and collaboration cues in the Feature list like on the web.  NOTE: This version (1.17) will be required to connect to Onshape once we enable the subscription plans.  If you are already part of the alpha, you should have received an email about upgrading.
Highlights include:
  1. Sharing with organizations.
  2. New feature dialog UI (remembers size, constraints list, active highlighting for errors,..)
  3. We can now view Versions in read-only just like the web version.
  4. Polygon tool has been added.
  5. Enable/disable sketch inferencing.
  6. Users can now see collaborators in the Feature list.
So fire up your iOS device and put it to a design test of your own.  We are interested to hear your feedback and hope to see some amazing mobile-designed products hit the stage soon!  Enjoy!  ~Lou
    edited March 2015
    Today we turned on our subscription plans.  For those of you who have prepaid, someone should have reached out to you and your Documents page should appear no different that it used to.  Everyone else will see the below interface.  The Free plan will have the ability to access up to 5 private, active documents at one time.
    Active/Inactive:
    1. You have 5 tokens you can place on any of your private or "Shared with me" documents.
    2. Public documents do not count against your Active documents
    3. You may create as many documents as you like (once you are at your 5 active documents limit, new documents are created as private and inactive)
    NOTE: Currently you must toggle active/inactive from Onshape in the browser since it is not yet supported natively in the iOS app.
