Export from file selection screen
mcconnell113mcconnell113 Member Posts: 74 ✭✭
It would be wonderful if you could export something directly from the menu where you pick your file. Instead of having to fire up the file then export. BTW it's still a bit unclear to me as to how im supposed to export a .dxf. I see that i can right click on a sketch and export as either dxf or dwg and on part i can export as stl. Will exporting by right clicking a sketch give me the entire part in dxf format?
John McConnell - Let's change things.
Saplingstore.com
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,147 PRO
    You can right click and export face as .dxf or Sketch as .dxf. Don't think there is anyway you can get the entire part.
    You could make a sketch and project/use (u) edges to produce a view for export of the entire part in 1 plane.
  • mcconnell113mcconnell113 Member Posts: 74 ✭✭
    that sounds pretty ugly.
    Saplingstore.com
