Rotate part along x axis
quinn_laird997quinn_laird997 Member Posts: 3
Hey there,
How do I rotate a part along the x axis? I can only get it to rotate along the y axis by selecting an edge of extrude. Basically it spins instead of tilting.
Thanks.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    quinn_laird997 ,You can use view cube arrow option to rotate as below,
  • quinn_laird997quinn_laird997 Member Posts: 3
    Thanks Narayan but what I mean is actually rotating the part along the plane (by using Transform I do believe), not just the view. I ultimately need to make a pyramid with 4 of these rectangles.
    I need to use precise angles.
  • shanshanshanshan Member Posts: 147 ✭✭✭
    quinn_laird997,as you said ,you can rotate it by using Transform ,you have to choose a proper axis for rotating , if this axis is not available , maybe need you to create it manually .
    11.JPG 85.9K
    edited April 2016
    @ quinn_laird997 , For that i suggest you to create a sketch. and use that as axis of rotation.
    Rather than rotating a vertical beam you should consider creating your pyramid structure using one or more sketches then sweeping the profile along each edge. That way you have much more control over your model and your angles.
