Deduce a existant diameter or project a face
clément_schreiber
clément_schreiber Member Posts: 2 ✭
edited May 2016 in FeatureScript
Hello,
I would like to make a new Feature with FeatureScript. I would like to automatize the creation of screw thread. To do this I need to create a sketch on a surface. On this sketch I have to project the circle, or at least know the diameter of the screw.
For the moment, I could create a sketch plane with a circle but I could not deduce the diameter of the screw.
I absolutely need this function. If there is an other existent Feature to automatize the creation of a screw thread or a cosmetic screw thread it will be excellent.
I hope I was clear in the description of my problem. :wink:
  • afbenevides
    afbenevides Member Posts: 4 EDU
    Hi,
    The info you need is in this thread https://forum.onshape.com/discussion/comment/4867/#Comment_4867 (comments from @Coleman and @LouGallo )
    Just need to automate these steps with the feature script code.
    Hope it is usefull
  • clément_schreiber
    edited June 2016
    @afbenevides: Thank you for your answer, but I know how to do it graphically, but I am to lazy to do it each time I need it. It's why I would code a function with features
    @kevin_o_toole_1: That is great! Thank you very much. :tongue:
