Comments, screenshots, Sketch book
hello all
while constructing and after for documentation, I have to pack some notes (text, links, screenshots) together and most useful, they are all inside the workspace instead another cloud.
I can import pdf's, pictures and so on. fine.
but often I make only a screenshot somewhere, even out of a larger pdf or from web as a snippet. Then this can be imported.
disadvantages: must first save the screenshot - because the is no direct paste - and each will be an own tab. not so clearly and tighty.
https://forum.onshape.com/discussion/3495/notes-for-workflow-and-comments-for-collaborators
comments are great because a direct link to an entity is possible.
disadvantages: does not survive a workspace copy - sorry, I am a beginner and I have to clear the history from time to time. also picture can't be pasted. and http:// - text is not available as a link (ok, super minor item).
https://forum.onshape.com/discussion/1017/add-image-picture-to-sketches-sketch-picture-implemented
sketches are place to hold several pictures together. ok.
disadvantages: using text isn't so handy there..., access only over part studio and then sketch....
drawings: did not find any import for images or free text...
is there a more convenient way to hold some notes and screenshots together? how are working others?
thanks in advance, best
https://forum.onshape.com/discussion/3905/storing-documents-on-a-branch#latest
It maybe nice to have a Onshape Project Note section linked to the document that works a bit like evernote with an option to keep or discard when copying.
Twitter: @onshapetricks & @babart1977
but: why must the document with the imported image keeped all the time? otherwise an error 404 will result....
or stacking the unused picture-tab into a folder would be useful for more clarity
note with leader does not work on a picture while balloon does it. but the the endpoint of balloon can never be repositioned, springs back all the time.
