Forget the Parametry
mevalemevale Member Posts: 22
OS should educate (slowly) to the engineers that parametric with its constrains is starting to be the past of CAD.
A real democratic CAD software can be able to create and EDIT any 3D CAD solid.
OS have the enviroment.
Go for the PROFESIONAL Direct Design!!
«13
  • caradoncaradon OS Professional, Mentor Posts: 300 PRO
    edited March 2015
    This is my view on this topic:
    • Direct editing is very helpful for manipulating imported geometry (no features present).
    • Direct edits can come in handy for making changes 'after the fact' in a parametric model. E.g. You modeled ribs in a plastic part to have 1mm thickness, then the molder suggests a thickness of 0.85mm. You do the change with a direct edit appended to the feature tree. (I have found this to be a great way to keep track of design canges as well, regardless of any PDM system used.)
    • It is impossible to omit paramtrics entirely! Whenever configurations are involved or intelligence in how design features are related (e.g. "This hole should ALWAYS be 50mm from that hole."), parametrics are essential. You will always hit a wall with a pure direct modeling solution in a real production environment.
    Just my 2cts.
    Dries
  • pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    Parameterized models can also be very useful for engineered to order type products. Products that are the same but slightly different each time. These types of models can be driven by things like DriveWorks. The CAD realm needs both direct and parametric type systems for different reasons. The direct method will be absolutely essential for bringing models in from older generation packages and not having to recreate data from scratch. I think we'll see more direct and parametric geometry tools coming from Onshape.
  • mevalemevale Member Posts: 22
    DriesVervoort_Caradon said:
    • "...Direct editing is very helpful for manipulating imported geometry (no features present)..."
    I differ with you. Design a NEW concept in Direct Design is faster that parametrically.
    "Well defined" Sketches to do solids to do layouts??
    It sound to me as a double work. Can you see where the waste time is?.
    Anyway, The first stage in any project is CREATIVITY and constraining (its name speak for it self) in the begining is against the creativity.
    • "...It is impossible to omit paramtrics entirely!..."
    Wait !!
    I know CAD programs that can do very complex plastic parts without any parametric trace.
    How can you explain that?
    • "...Whenever configurations are involved or intelligence in how design features are related (e.g. "This hole should ALWAYS be 50mm from that hole."), parametrics are essential..."
    You are right with the "ALWAYS", but what about with the "NEVERS", engineering changes are nevers, and here is where direct design is better than.
    Have you tried to edit parametrically a complex 3D solid made for other engineer? 8 )
    edited March 2015
    • "...Parameterized models can also be very useful for engineered to order type products. Products that are the same but slightly different each time..."
    I know not parametric CAD software that can do that.
    What Direct Design software you are taking as example?
    • "...The direct method will be absolutely essential for bringing models in from older generation packages..."
    Direct Design IS faster to satart a NEW design, not just "to bring back old solids".
    I am surpised with the wrong concept the people have with Direct Design, here is where OS has the oportunity to evolve and jump to another level to work.
    OS has the right enviroment, OS need the right and real democrartic tool.
    edited March 2015
    @manuel For designs that are similar yet different, there is no way direct editing could compete with a parametrized model and a product configuration tool like driveworks.  Go watch this video to get an understanding. There are many more videos like it on their YouTube channel.
    https://www.youtube.com/watch?v=7w5Wfersg2Y
    edited March 2015
    Each approach has its merits, as well as downfalls, as well as ideal use cases.
    For some designs, parametrics are best. For others, a pure direct approach is best. Direct modeling is indeed very welcome in (some) initial conceptual design!
    However, you can't cover all design problems with pure direct modeling. How do you handle configurations/design variations in a direct modeler?
    All pure direct modeling packages currently in the market are niche players and have been for many years.
    I'm interested in knowing your view.
    Dries
    @Peteyou're talking for a Specialized Module, obviously the standard CAD can´t do that.
    I know some modules for Direct Design CADs that standard or profesional or premium SW can´t do.
    Apples with apples.
    edited March 2015
    • "...For some designs, parametrics are best. For others, a pure direct approach is best..."
    Sorry I can´t see the diference, can you tell me examples where and when is one better than other?
    • "...However, you can't cover all design problems with pure direct modeling..."
    Yes it can, I don´t know what Direct Design are you taking reference for.
    Can you send me a part and tell me what do you want to modify?
    lets try it!! (i can upload a video)
    • "...How do you handle configurations/design variations in a direct modeler?..."
    Whatch this example on a Direct Desing CAD. No parametric anywhere.
    You can delete or add dimensions whenever you want.
    www.youtube.com/watch?v=B7xZgjXaT-U&ab_channel=Kubotek3D
    https://www.youtube.com/watch?v=B7xZgjXaT-U&ab_channel=Kubotek3D
    OnShape is starting, this is the right moment to decide the right tools.
    Direct Design in OnShape are "toys" compared with the profesional DD in the market.
    Apples with apples.
    Standard CAD can do some of that.  Design tables, configurations, etc...  DriveWorks is just accessing the API of SolidWorks to drive it that way.  DriveWorks is a rules based system that runs SolidWorks to change the design.  There are other packages that do the same.  The rub is they all need parameterized models in order to do that.  Without parameters, you couldn't automate it.  With direct edit models only, I'm not sure how you could automate different designs like this.  That is probably the example @DriesVervoort_Caradon was referring to (sorry to put words in your mouth Dries).
    No worries. That's indeed what I meant.
    Parametrics aren't going away anytime soon.
    However, I would certainly appreciate expanded direct editing tools in Onshape. :)
    Dries
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    Following this with a chuckle. People who say "I can do anything with direct only" have never had to churn out modifications or linked drawings on a regular basis. Neither have they ever iteratively done any advanced surfacing work.
    direct modelling...Spaceclaim..fantastic app for certain tasks. But Rhino is a direct modeller as well, for the most, but really, so tedious for doing complex tweaks to form on a developed model.
    As Peter says, history based modellers like SolidWorks wipe the floor with pure direct modellers for logic based design (aka Driveworks type use). Seriously. I did a benchmark a couple of years ago for a customer where we took the SolidWorks files of a product which was driven by 2 sketches and linked patterns, with linked drawings to that. We tested Spaceclaim, SolidEdge and Inventor.
    The task was produce a new design in under 30 mins with linked approval drawings.
    Spaceclaim? All that selection, moving etc etc. Took 2.5 hrs.
    SolidEdge...took 40 mins...using History. 2hrs using ST.
    Inventor...took 30 mins
    SolidWorks...25 mins.
    but its not just for logic based design tasks. Try driving a complex surface model using direct only. Its not like we don't try either. We use Rhino, Tsplines, Modo alongside history based systems like SolidWorks and Shark. Sub D is not the answer...only applies to a small proportion of design work. Production level surfacing is about subtle control, accuracy, editability. Some of that you can do with direct, but only with VERY costly direct systems!
    So much of the "the future is direct" bandwagon is based on editing prismatic objects. Any decent CAD system can do direct operations. I see so much toss at demos importing dumb solids and saying "look, we can edit this fillet". Wow. The $99 ViaCAD can do this. Nothing new.
    So, I'm not wanting to get into a big argument on direct vs history. It is irrelevant. We need both approaches in one product. Not one or the other. Both.
    edited March 2015
    Kevin Quigley said:
    • "...Any decent CAD system can do direct operations. I see so much toss at demos importing dumb solids and saying "look, we can edit this fillet". Wow. The $99 ViaCAD can do this. Nothing new..."
    Direct Design is not just modify, Is mixing, complementing, interacting with wireframe, surface and solid ALL in one enviroment.
    I don´t know what Direct Design have you seen, but for sure not the profesional one.
    • "...People who say "I can do anything with direct only" have never had to churn out modifications or linked drawings on a regular basis..."
    Wrong, the "Never" word means you know what all Direct Design user do. Do you?
    A simple example on how wrong are you. I challenge you,
    Try to do this in less than 5 (five) minutes with SW. (data is the video)
    You will have all the time you want to do it. Tell us the result.
    www.youtube.com/watch?v=onXOVXkV-Zs&ab_channel=ManuelValenzuela
    • "...Neither have they ever iteratively done any advanced surfacing work..."
    Ohh.. man you are funny, 8 ) smiling.
    • "...Try driving a complex surface model using direct only..."
    All in one, as you can´t see neither Rhino nor Tsplines are present.
    www.youtube.com/watch?v=_QO1AanCNtI&ab_channel=Kubotek3D
    www.youtube.com/watch?v=4QJ4vWb9shc&feature=youtu.be&ab_channel=ManuelValenzuela
    https://www.youtube.com/watch?v=4QJ4vWb9shc&feature=youtu.be&ab_channel=ManuelValenzuela
    • "...We use Rhino, Tsplines, Modo alongside history based systems like SolidWorks and Shark..."
     C´mon. Are you saying SW needs Rhino or Tspline?? Or you need them? both are not the same.
    • "...So much of the "the future is direct" bandwagon is based on editing prismatic objects..."
    Yes, you are funny  8 )
    So far, mathematically, topologicaly the very nature of complex surfaces cannot make it editable with dimensions.
    Or what are you talking about?
    edited March 2015
    • "...The rub is they all need parameterized models in order to do that.  Without parameters, you couldn't automate it..."
    Oh.., you didn´t see the video,.here is again.
    This is a Direct Design software and it doesn´t need be parametrized to do a variable product configuration.
    @Manuel Lets agree to differ on this one. You have your point of view. I have mine. I prefer to have a full toolbox than half a toolbox. You can build most things with a saw, file and hammer but it is sure as hell easier if you have a laser cutter, CNC mill and 3D printer handy as well. I'm not sure if you are a Kubotek reseller or not but suffice to say I've seen and used the product and there is nothing it can do that you can't do in any number of systems like Shark, Ashlar, FormZ or any other ACIS based solution.
    I also think you misunderstand what I mean by iterative production surfacing. That video of the shoe sole is a great example of what I call static surfacing..you create the curves, create the surfaces, the to edit it you basically rebuild the areas you want to edit. You can take that approach on any CAD system worth using. This was exactly the approach we used in the late 80s. Not new. This is essentially the same approach Rhino uses...where if you are lucky you can maintain associativity for a feature. This does have its place but for iterative design it is a tedious innefficient approach.
    what I mean by iterative design is creating the curves, creating the surfaces/solids then iteratively editing the shape (not just fillets as in the helmet example), the whole or localised areas of the shape, but tweaking the driving curves or directly editing the surface CVs. If you want examples of a similar to KeyCreator product but one that has full associativity from curve to surface to solid look at SolidThinking or SharkFX.
    But the bottom line is this. We use Solidworks, Modo, Rhino etc because each has its own benefit for different design tasks. People who say one solution and one approach meets all needs are either selling a product or working in a limited methodology in a restricted design area. We don't. We design everything from bathtubs to speculums. One solution does not fit all.
     Finally, you can in fact drive a surface with dimensions, very easily. SolidWorks has the cabability to drive CVs on splines with dimensions, as does many other systems. And very useful it is too.
    So lets not get into an argument over this. It is only CAD after all, and most people here have been doing it a long time, and seen most of what is on the market. What we want is a new approach, not a rehash of old ways.
    @Manuel I watched the video. Looks like Kubotek is creating parameters to quickly change the model. So you're saying that parameters are good? I think you are proving our point. Parametric and direct are both needed.
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,470 PRO
    In the beginning, OS shouldn't be too much different from mainstream cad like SW and others. Just create perfect parametric dimensioning in paraller of developing advanced direct modeling. Designers time is valuable - if we find direct modeling to be the way instead of sketches the movement happens itself.
    If OS would choose to go just direct modeling from the beginning and wouldn't develop perfect sketching environment - it would be too different to easily learn for people usign mainstream 3d modelers and propably would end up being just another weirdo on the web.
    At first we need true cloud based alternative to current market leaders - then OS can show new directions for design workflow too.
    //rami
  • MarcoRMarcoR Member Posts: 1
    I think we should have the choice!!!
    To design new things, it's easier un direct modeling (just take a look at Ptc Creo Elements direct modeling or Ironcad). There are no parameters or contraint in sketch. 3d parts are stretched like un 2d cad... If you have to built tour machine more than once with small change parametric is the way to go
    But parametric cad softwares are better and faster for machine production. In the past I worked for a company which was making "900 series" conveyor... These " 900 series " conveyor were always built the same way except fort width and length... In parametric cad, 2 parameters need to be changed and the modeling and drafting work was done... You have to think which paramètres are required but when it's done it's very fast to generate drawing...
    It depend on what you are designing and will you design it on a regular base...
    Sorry for my mistake (my primary language is french)...
  • andrew_troupandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭
    edited April 2015
    Direct editing may well be significantly better for consumer product design, but I entirely agree with those who point out that parametric wins hands down for machine design, mechanisms, engineering components and the like.
    I think this discussion is one where individual users are seeing something in the OnS business model which appeals to them, and thinking that their particular area of design is (or should be) the target market.
    Specialised packages will always outperform more versatile ones in their area of specialisation.
    I personally get involved in all the areas mentioned above, and dozens more, and the compromises involved in using a parametric modeller for ID pale into insignificance alongside the difficulties of trying to use a modeller optimised for ID to design engineering componentry and mechanisms.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 1,992 PRO
    edited April 2015
    Ok, how about this crazy idea....
    -Engineering works in a parametric world
    -Then you branch, turn off parametrics and release to manufacturing
    -Manufacturing can tug and pull the model into place using direct modeling
    -Then you merge the direct modeling changes back to engineering (parametric world) for the follow on r2 design.
    I find it crazy what manufacturing does to my engineering layouts. They destroy it every time. Most companies don't archive the engineering layouts and only control manufacturing documentation. Finding the latest engineering layout is always a pain especially if theres 400 pack-n-go folders and you can only sort based on modified date. The existing solution industry uses is half-baked.
    To defend manufacturing, they have no idea what the design intent was or how the parametrics were put together. It's really impossible for them to work on anyone's layouts and therefore they strip out all the goodness. Once it's gone it never comes back and the dance steps repeat over and over again.
    I realize there are guys like Bruce that have figured out a tight system and can control everything for a small production shop. But for most companies, it's not working.
    What's the craziest thing manufacturing has done to your engineering layouts?
    -remove all assy references
    -save everything to a parasolids file
    -circle interpolate splines
    -un-virtualize an assembly
    I'd like to see one model make it through engineering->manufacturing->engineering........
    I haven't seen this work, ever.
    @billy Ohhh, ouch.  Tough system to live in pack and go series of folders.  Long time user of PDMWorks WorkGroup and now EPDM.  All 3 of these systems are light years behind CAD designed around a really good database in the cloud where no copies need to go anywhere.  Pure design goodness without the hassles of managing what ends up to be really complex systems that require too much of our attention.
    I hope direct and parametric can be married together in Onshape... intelligently.  Could be awesome.  I am becoming convinced that feature based history methods are not nearly as superior as something else currently out there.  I wish, I wish.
    I don't know much about direct modeling but if all dimension are driven would it make the parametric model open for direct editing and still keep the parameters in place?
    //rami
    Its better than that.
  • quentin_4quentin_4 Member Posts: 7
    Hi Everybody, I just read you and I would like to add my personal feedback about direct modeling technology.
    I'm working on SolidEdge and mostly designing electronics parts.
    In my company, references are organized with families of product (40 pieces in 1 family). Each family’s assembly has mostly the same design, only 1 or 2 dimensions are changing from one to another.
    To model them, I'm using the parametric technology. Indeed the fastest way to build all models is to create an adjustable master model (native format) and extract the slaves (for release: Step, Iges...) Time => 15-20mn for basic parts from 0 to 40 assemblies done and extracted.
    => I've try to build an adjustable part with direct modeling technology and many problems occurs:
    -You lose the link between sketches and functions.
    -Pattern parameters are limited.
    -I need to add dimensions on symmetries. If I don't, it moves when I adjust the part. (move it manualy)
    -Till I want to make a dimension adjustable, SE switches automatically to the parametric mode and shows an error message.
    Basically I can build exactly the same part with synchronous technology, but it will take 20x more time because I have no way to make my models adjustable automatically. So I must draw them one by one. It makes this solution not viable for my job.
    => For the kind of design I would like to do, the following parameters should be apply: (starting from direct modeling mode)
    -Keep a link between sketches and functions
    -Pattern features should have the same parameters available as in parametric mode.
    -Adjustable dimension must be editable in direct modeling mode.
    Good points for DM technology => Drafting liberty and editing facilities.
    Bad points => Geometry lack of control leads to an impossibility to create adjustable parts.
    A mix between both technologies might be the best, but here we have a turning point between users. Indeed we do not all expect the same behavior. The solution might be to entirely set up the software behavior for each use.
    The issue is the barrier between direct modeling and parametric mode, maybe we should search ways to make them work together instead of saying: "This one is the best!" ;)
    @QuentinWould it be overly simplistic to summarise part of your thoughtful contribution something like this:
    Parametric design is about incorporating design intent, particularly (for the purposes of this discussion) with respect to likely future changes or variants.
    So ... in cases where the future of a model cannot be predicted, or where variants will not be generated, the extra burden of full parametrics may not be worth carrying?
    @Andrew_Troup: Yes it is right we could say it like this.
    I do the link between my current activity and the title "forget parametric".
    In the beginning we use the direct mode to validate the design => Variants not predictable => too many constraints in parametric mode as you said.
    Then the parametric one for "slave’s creation" => Variants is knew and I just need several models with different sizes => not enough geometry control to set up "automatic" models
    So, in order to reach the idea: "forget parametric" I suggest it might be a good thing to have it in one mode which allowed both best features.
    Which would means to be able to set up your software behavior to be compatible to everyone's needs.
    edited April 2015
    If these guys don't run out of funding and can make their technology work with 3D sketching things might get interesting for direct modeling:
    http://www.cloud-invent.com/about
    Jon Banquer
    CADCAM Technology Leaders group
    I don't believe this statement of theirs is correct although I could be wrong...
    "We, in Cloud Invent, see this “synchronous” approach as the dead end way of blending parametric and direct modeling, because in its depth such a CAD
    application contains the same history tree, with all its inherent drawbacks."
    I do think there could be some awesome things in this area, though.
    Pete, I'm sorry I didn't understand your comment. Can you open up a bit?
    For the topic:
    I have tried direct modeling few times but I don't see a reason to 'Move a face' since I can just set new value for parameter to achieve the same.
    Only thing it has been good is modifying imported files without history.
    Don't get me wrong, I'm not against direct modeling - I just don't know where or how to use it effectively. How do you begin from blank screen with direct modeling? How do you create anything precise without dimensions and if there is dimensions what's the difference then (dimensions are parameters, right?)?
    //rami
