If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
How to copy an Assembly tab?
emerson_bottero265
                    Member Posts: 2 ✭
                                  in General
                    Is there a way or workaround to copy/duplicate an Assembly tab? I already have one and I need another almost iqual, with just a few parts replaced.
Ok this works better.
Shift select parts and sub assemblies from the tree, copy, paste in space to the side, select the new bit's in the tree and form new sub assembly. Switch to new sub assembly to continue work ( I had to position the main bits to the origin, delete un want parts and add alternative parts). Delete the new assembly from the parent, in my case I wanted the both parent and child to appear in the next assembly up so just dragged the child from the parent to be be included into the top assy, worked a treat.
Twitter: @onshapetricks & @babart1977
@emerson_bottero265 , Kindly use below video method as suggested by @malay_kumar which will be helpful to you.
