What does blue extruded geometry mean?
bryan_stamand
bryan_stamand Member Posts: 1 ✭✭
edited June 2016 in Community Support
I assume it means something isn't constrained. I am having an issue lofting between 2 sketches and a solid face. I did both sides exactly the same. One side is showing normal geometry and the other side is showing blue geometry. Everything looks constrained in the sketches. I wish I could share the link but I made it private by default.
**edit** I figured out how to make it public. I also realized it made it a new separate part (down right.) Its now part 2????
https://cad.onshape.com/documents/29b9f200c219f2a2d4de477d/w/9a60cc44382a406f22cd9c6d/e/53c0116c96ccaa7fd71bc341
  • andy_morris
    andy_morris Moderator, Onshape Employees Posts: 87 image
    edited June 2016
    Hi Bryan,
    The loft command enables you to create new parts or add/remove from existing parts. In your case the "blue" geometry is a second part.
    Andy
    Andy Morris / Head of Product Design / Onshape, Inc.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ bryan_stamand, are you talking about "Loft1" in your feature tree?
    If so then Please find the below difference,
    1.PNG 41.9K
    2.PNG 40.4K
    3.PNG 44.5K
