How can I measure distances between different parts ?
I'm frustrated because I need to check up the distances between parts using the dimension tool, or even between different entities on the same part ( that I solved badly by creating a drawing and inserting a part and used the different dimension tools, but I had to go back and forth between part studio tab[to change] and drawing tab[to check], but then I realised that the drawing didn't change and I had to create a new drawing and insert the same part I wanted to check after the changes....), I found another way to make distance relations between different parts but only while sketching and only on the same plane, and the extruded parts doesn't have sketches in the plane I want to do my check on. I think I will have the same problem in the assembly tab.
  • shaddy_eldesouky
    shaddy_eldesouky Member Posts: 6 ✭
    thanks for the response, https://forum.onshape.com/discussion/comment/18865/#Comment_18865 this is a thread about nearly the same issue that I commented in earlier, but what I remember is that the measure tool didn't do the job then and I had to use the drawing tab work around which was not convenient at all and I had to go back and forth about seven times to adjust the distance, to be honest I used it now after your answer and it did the job in this case but I really don't remember what was the case then, maybe when I get used to the tool I will have no problem, I prefer having a measuring tool like the one in the document tab, if I face further measuring problems I will try to add it to this thread.
  • shaddy_eldesouky
    edited June 2016
    this is a case that I need to check the distance between the highlighted edge (or the centre) of the circle and the straight line from other part on this 2d plane and the Min dist: 3.955cm is probably in 3d because it should be around 1cm
    so I went 3d and tried to choose the edge of the cylinder which is on the same plane I want so I can get the Min Dist I want but I couldn't and the whole cylinder was selected, I guess the result now is what I want but I'm not certain, and I need information that I can rely on.
    I recommend: 1- colouring the measures with the same colour of the part( instead of typing length or area of name of part and instead of leaving length or area undefined)  2- clarifying in the help page  https://cad.onshape.com/help/index.htm#measure-ps.htm?Highlight=measure that the measuring of parts is in 3d so you should make your selections in 3d and not in 2d plane to avoid misleading info.
    3.jpg 42.5K
    2.jpg 50.6K
