Semi-spherical container
thomas_kozak
thomas_kozak Member Posts: 38 ✭✭
edited June 2016 in Community Support
The goal is to design a container (partial sphere) of given volume which is attached to a plane via a port of a given radius.  Ideally these would be parametric. I believe this can be done via variables but constructing the expression is giving me problems.
The sketch would be a circle split by a chord of constrained length (2*radius of the port).  The radius of the large circle should be definable by the length of the chord and the known area of the resulting circular cap.
    NeilCooke Moderator, Onshape Employees Posts: 6,108 image
    Actually the math is quite horrendous as you have to solve a depressed cubic equation. Needs someone far more clever than me!
  • thomas_kozak
    Thanks in any case for the input!  For the time being I'm giving up on formulating it directly since that math is over my head too.  Fortunately I think I can write some javascript to brute-force approximate the radius of the sphere which will be a good patch until I can figure out the right expression.
    Actually you could write it fairly easily in FeatureScript, doing an iteration until the volume is within a certain tolerance.
  • thomas_kozak
    That's a nice bit of featurescript, thanks!  Pretty much how I was doing it in JS, but directly in onshape.  I'd still like to be able to get the exact value via an equation but I guess I'll have to hit up some math folks.  This will work for now.
