round( ) function
tim_ashbytim_ashby Member Posts: 3 ✭✭
Is it possible to specify the number of decimal places that the round( ) function rounds to? The standard Excel format of round(number, dp) doesn't seem to work. Alternatively, is there a workaround?. Thanks!
    edited June 2016 Answer ✓
    round(value * 100) / 100 should do the trick (to 2 dp)
  • patrick_farleypatrick_farley Member Posts: 37 ✭✭
    round() as now a value and a multiple.
    @patrick_farley
    round(value, .01) is probably what you are looking for rather than round(value, 2):
    https://cad.onshape.com/FsDoc/library.html#round--
    You'll notice also in that documentation that value and multiple can also both be valueWithUnits, and the result will come out as a plain number (whose "unit" corresponds to the "multiple")
  • leon_tullingleon_tulling Member Posts: 12 PRO
    edited June 2024
    I'm trying to use the solution above, but I keep getting errors (Function Round with 2 argument(s) not found). Any idea what can go wrong here?
    Part of my code
    var es = definition["segment" ~ i] / millimeter;
    partNumber ~= toString(round(es, .01));
    Creative Technician Mechatronics | Freelance Engineer
    www.leontulling.nl
  • _anton_anton Member, Onshape Employees Posts: 515 image
    @leon_tulling You're likely on a very old version of the FS standard library. The two-argument function was introduced around six years ago.
  • Eric_WongEric_Wong Member Posts: 24 PRO
    @leon_tulling roundToPrecision() is the new way to do this. See here https://cad.onshape.com/FsDoc/library.html
