<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
how do you create an offset surface?
dave_cowden
dave_cowden Member, Developers Posts: 484 ✭✭✭
I would like to create a surface that is an offset from another one ( either a face or a surface).
I have found offsetFace-- but this moves the face, instead of creating a surface.  This seems like something that should be possible, but I can't find it...
thanks as always.
  • dave_cowden
    Good tip, thanks! That could work. But how do i go about thickening the face, then extracting the surface, but then removing the thicken so i dont affect the underlying geometry?
  • dave_cowden
    well poop, that doesnt work-- because i guess you cannot call that if you are a 'regular user':
    Any other ideas?
  • dave_cowden
    Unfortunate. this is a pretty major limitation.
  • Larry_Canipe
    Larry_Canipe Member Posts: 1 PRO
    Has anyone found a way to just do a surface offset. I have yet to find a way to just have the part surface from the model.
  • dave_cowden
  • tim_waldemer
    tim_waldemer Member Posts: 10 ✭✭
    First do a transform on the subject surface using the copy in place rule.  Then temporarily hide your original surface.  Lastly, do a move face on the surface using the offset rule.  This gives you a true offset surface while keeping the original surface.  Hope this helps.
  • kevin_o_toole_1
    John is correct, but just a point of clarification:
    These functions are still marked @internal because we may change their behavior slightly (especially with respect to error handling) in the future. This means that the next time you update the FeatureScript version of custom features created on top of these functions, individual features may behave differently (or fail) when they update their links.
    The functions are useful enough that they were worth exposing anyway, but be aware that changes are a possibility. Here's a doc where you can play around with some of the current behaviors:
    https://cad.onshape.com/documents/dcbffeaede71bbfd8d37fc83/w/3ba91b4bc06d0a60cc11d2a5/e/9e9ed0e174274eeac7d26ac7
  • Chris_D_Mentes_001
    Chris_D_Mentes_001 Member, csevp Posts: 132 PRO
    FYI I seem to be using the function succesfully now so if anyone is trying it out just copy and paste the format from the std library source for Offset Surface
    S1mon Member Posts: 4,582 PRO
    Offset surface has been available as a standard feature for a while.
    https://cad.onshape.com/help/Content/offset_surface.htm
    And yes, it’s also available for use in FeatureScript.
