Add .dxf as a sheet in a drawing after importing?
jackson_king
PRO
Is there a way to add a dxf to an existing drawing? Such as formed model is dimensioned on layout 1 and then dxf added as layout 2 to represent to flat pattern of the part. Like a workaround for how SW let's you add either the flattened part or formed to a drawing.
Also, is there a way to chose the name when exporting to a .dwg or .dxf? Instead of the OS auto-created one?
1
@jackson_king Import the flattened DXF into a part studio sketch and create solid geometry. Then on the drawing, reference that solid geometry in a view that you create.5
Thanks for the answer @PeteYodis! I will give it a try. Any suggestions on how to get bend lines to show up through this process? When I import the dxf into OS I can edit it like a drawing and add the dims I want for the bend lines. I know sheet metal functionality is coming (soon?) but till then, if I could add in a .dxf into a drawing like you can a .jpeg, that would be pretty cool.
