Ball Mate limits...
Hi Peeps,
I'm exploring some of the options given us regarding limiting the movement of parts in an assembly.
I can see that, for the planar mate for example, you can set up limits so that your parts behave like they are hitting stops. Given that we do not appear to be able to use the solids to provide those "stops" then limits within the mate is the only way to emulate this.
I've just been playing with a simple ball joint assembly and there does not appear to be a way of limiting the ball mate. Am I missing something? Is there no way at all of limiting the rotation of a ball in its socket?
cheers
andy
cheers
andy
3
Narayan_K Member Posts: 379 ✭✭✭
@ andy_morris900 , Your correct.At present no limit for rotation.You can raise improvement request for this.
5
cheers
andy
Hope this will help you.
As soon as I apply a cylindrical constraint between the connecting rod and bush the connecting rod becomes frozen in place. I've had a look at the limits options and everything is set to no limit.
I'll need to play some more.
cheers
andy
