bug: mirrored loft guides don't snap
jin_kai_ng
jin_kai_ng Member Posts: 3
https://cad.onshape.com/documents/86b5e828d5c6262d70fbf34c/w/b7e76de41272f485c5c3661d/e/69c58b6f359f1e0454c25f83
change the angle of the line in sketch 1. this causes the loft to fail, because two out of the four guides (which are mirrored), no longer snap to the small circle.
Currently, I have to delete and add back the pierce constraint for the splines in sketch 4.
  • Jason_S
    Jason_S Moderator, Onshape Employees, Developers Posts: 225 image
    @jin_kai_ng and @narayan_K ,
    There are a few things happening here:
    1) None of your sketches are fully defined. When your sketch entities are black, they are fully defined. Fully defined sketches are good practice and will prevent issues downstream.
    2) I deleted your mirror and the desired geometry was generated. For this specific example, you don't need the extra guides provided by the mirror.
    3) "Pierce" constraints are external constraints (they will show blue if you check the "Show all constraints" check in the Sketch dialog). External constraints are dropped on purpose in patterns and transforms. Dropping these constraints helps with way more cases than it hurts.
    I hope that helps. Let me know if you have any more questions,
    Jason
    Support & QA
  • jin_kai_ng
    edited July 2016
    @jason_slingerland
    @ 1) Okay, good to note.
    @ 2) No, I do need the mirrored splines. The same model with splines exaggerated to show why (left right should be mirrored, but are not if I do not include the mirrored splines):
    @ 3) What other constraint should I use then? 'Coincident' doesn't seem to work.
