New FeatureScript: Pocket Holes
eisen_montalvo
eisen_montalvo Member Posts: 3 ✭
Hi everybody,
I would like to share my first FeatureScript: Pocket Holes. The feature is very straight forward:
  1. Choose entry face
  2. Choose exit face
  3. Select vertices where the pocket holes will be created
  4. Select thickness of part that will have the pocket holes
You can find the FeatureScript here: https://cad.onshape.com/documents/5c9f5a0c9e9568a64f8fce0f/w/5f5fb2a214796377ad0d8f98/e/6290b4d3ef8ef9df035b121a
Future improvements:
  1. Calculate thickness automatically from the part
  2. Add option to add mate connectors for screws
Let me know if you have any other ideas.
    Thanks @eisen_montalvo for posting your custom feature - here is my unfinished attempt:
    https://cad.onshape.com/documents/06fec7e8ca6ea0debc1b30cc/w/d458179d8dece090228faee2/e/7e02268cde3b2bc764d68f52
    I was focused more on selection rather than correct hole sizing, but you will see that with a single edge selection it will work out which face is which and the thickness of the part and place a number of pocket holes. Please feel free to merge the two codes together to make a super custom pocket hole feature!
  • bobt
    bobt Onshape Employees Posts: 7 image
    Checkout std/cylinerCast.fs. This is the utility function used in our hole drilling. It has facilities to measure the starting point for the back side drilling. If you and questions, feel free to ask.
  • eisen_montalvo
    Thank you @NeilCooke for sharing your code and showing me a different way of thinking and solving problems in FeatureScript.
    I went ahead and merged some of your code, added the mate connectors, and simplified the interface. Now
    there are only three options:
    1. Edge
    2. Application type (90 degrees or straight)
    3. Option to add the mate connector.
    The thickness and the location of the pocket holes are calculated automatically using the suggested distances from Kreg. I'm pretty sure the code can be optimized quite a bit. But for now, it does the job. I will optimize the script another day.
    Thank you @bobt for sharing the code. I need to dedicate some time to go through it. When I have questions, I will sure to ask.
  • lane_slabuagh
    lane_slabuagh Member Posts: 1 ✭
    @eisen_montalvo - how do I access your code?
    When I click it, it says the following:  "Failed to load document for workspace. Resource does not exist, or you do not have permission to access it."
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,275 image
  • eisen_montalvo
    edited July 2016
    I'm sorry Lane, I forgot to update the link after making some changes that Onshape requested. Thank you Ilya for replying with the correct link.
  • dave_odle
    dave_odle Member Posts: 4 ✭
    edited July 2017
    THIS DOESN'T WORK ON SHORT PARTS UNDER 4 INCHES.
    IT LOCATES THE POCKET HOLES TOO FAR APART.
    ALSO IS THERE A WAY TO HAVE AN INPUT FOR THE NUMBER OF HOLES WE NEED ON A EDGE
    ALSO A DISTANCE WE CAN SET FROM THE OUTSIDE EDGE IN
  • brett_sutton
    brett_sutton Member Posts: 43 ✭✭✭
    Agree with dave_odle, needs an option to control the distance between holes, inset from a second edge selection and finally a 'count' to control the no. of holes to cut starting from the inset edge.
    These three options (together with your current 'auto mode') would make this feature script perfect.
    Well done on the initial script though!
  • william_brooks158
    william_brooks158 Member Posts: 8 ✭
    Hey folks - I know this is an old thread, but I needed the custom pocket holes @brett_sutton & @dave_odle referenced above, so I hacked together a version that does it.
    • Custom 1-hole, centered option
    • Custom number of holes with custom spacing from ends
    I'm fairly new to this forum - What's the best way to share this for feedback & for folks to use?
