How can you create a drawing of assembly?
in Drawings
please help me
1) Give proper constrain to base part of assembly with respect to origin so that at least one face of base part is parallel to any plane.
2) By changing rotation angle in view properties
Rotation angle: All views, when created, have a rotation angle of 0 degrees. You can change this value only if the view has no parent (is not a 'child'), is not a parent (has no 'children'), or if the alignment with a parent is broken.
Valid values are between -360 and 360 degrees.
Tips
