Cut/intersect according to two lines on different directions
alec_liu
Member Posts: 4 ✭
Please forgive my ignorance. I am new to CAD tools. I want to cut a shape with nice diagonal angle. Can someone guide me step by step to make a smooth slide from one line to another line? Please see the attached.
I want to cut from A to B and C to D (with certain thickness).
This is so far I can do but the shape and angle isn't ideal. I hope someone can guide me a better way to do it nicely.
Thank you!
.Thank you!
mahir
Member, Developers Posts: 1,323 ✭✭✭✭✭
I solved the instability by adding an intermediate profile. Should be good to go.5 -
Narayan_K
Member Posts: 379 ✭✭✭
alec_liu, As you said i have created a curved part with 0.3mm thick(i assumed that it is millimeter) you can check "Part 2" in the below link.Which similar to mahir model.
https://cad.onshape.com/documents/57a17d4be4b0063191e34a43/w/57503dbbd9f36b0dd86cdb5c/e/68d91033e473176f92a52430
5
https://cad.onshape.com/documents/a05aeff75e42296533f07199/w/3da90aff92f27b413a5f9fdd/e/3bde499347473efe5a1c1c52
