Bugs
josh_crowsonjosh_crowson Member Posts: 7 EDU
I have been having trouble with onshape.  Last night I could not export, and for 30 min got an export fail message.  Today, I could not get a sketch to extrude until I closed out my browser immediately.  This afternoon, I could not select a constraint to delete.  I have been using onshore since december with out issue.
    @josh_crowson Can you try this in Chrome or Firefox to see if this is an issue.  We have seen a number of issue with Safari in the 9.1.X version.  Can you send in a support ticket if this is also happening in the other two browsers?
