How do I create a -AN fitting? (as pictured)
dillon_smith
Member Posts: 2 ✭
there are many of these -AN fittings i would like to be able to draw but not sure where to start?would i just be following the same process as creating a normal thread?
also side note...for NPT how would i make the thread tapered in size like the fitting needs to be?
@dillon_smith
For standard fittings it may be best to import them as opposed to modeling from scratch because you are just creating more work for yourself.
There are a few applications from the app store that will allow you to import standard components in less than 1 minute.
Just conversationally there is never a reason to model screw threads. Period.
Yea, I get it and it's really cool, but the computational load of an assembly with more than a couple of these types of things will bring your model to it's knees.
Model threads with the OD as a solid face.
Seriously.
I've got the entire Parker fitting catalog modeled in SWx with configurations. It wasn't difficult and using configurations made it a lot more time efficient. Create the original model and then fill in the dimensions on all the various configurations. Not having configurations available would make this a VERY time consuming process to do from scratch.0 -
Except for we folks who are actually using the threads we model. On both sides.chris_dubea said:Just conversationally there is never a reason to model screw threads. Period.
Not everyone is designing things made from other folks' bits, or that even exist. I suppose one could limit yourself to poking holes in things but I have a few other bits that need making.
(Or, more succinctly, any time you ever say "there is never", you're wrong. Hideously.)0 -
I agree. I tell my students that standard tapped holes and screws/bolts don't typically need to be modeled with threads. But if the item you are designing has threads as a major feature and/or they are not standard, then you should include them. For example, if you are designing a collet-type work holding system that has a large thread and nut as primary features. I would like to see those in the model.SquidLord said:
Never is a long time.0 -
Or if you're planning to 3d print the item, you probably need the threads too..
Or if you create assembly instructions you need something similar to thread to make difference to a pin..
Currently mcads are used in so wide area that it is not possible to tell THE rules that applies for everyone.
//rami0
