Using feature pattern to instance?
Jlabs
Jlabs Member Posts: 28 ✭✭
edited September 2016 in Community Support
Maybe I'm confused on terminology, but in my experience an instance is a driven entity, meaning for example in an assembly with 5 instances of a part, changing the part updates all the instances. This doesn't seem to work the same with feature patterns or part patterns?
I have a 3-axis dolly with mounts at 3 points of the triangle. I want to make a change to the mount at corner one and have all 3 corners update with it. What is the best workflow to accomplish this?
Thanks!
  • Dylan_Stewart
    Dylan_Stewart Member, Developers Posts: 107 PRO
    Are you able to share your document with us?
    Digital Engineering
  • 3dcad
    Or at least some screenshots, it might be very clear when seeing the model and writing text - but (at least) for non-native english speakers like myself, it can be difficult to imagine what you are looking even though text might have all needed information.
    //rami
  • Jlabs
    I made a basic public version to demonstrate the problem. Basically, I want each corner to be the same, and any changes I make to the top corner should reflect in the other two corners. I found that I can drive the revolved feature with a single sketch, but once I make additional changes to the design (such as the hole I put in as a sample) how do I get those features to change on all corners? Do I have to array the hole feature separately? Is there a way to drive the corner features differently?
    https://cad.onshape.com/documents/83f432b287ac4f34390171d2/w/46e197fae444932654e74c49/e/3022f4aba56b02688ed05488
    Thanks in advance!
  • Jlabs
    Thanks for the reply. The problem with using an assembly is that it's meant to be a single piece, meaning the round parts at the corners aren't separate parts. Rolling back seems very tedious if I make other changes to the part elswhere. Can you roll back and still retain changes after the rollback point? I'm unclear how rolling back would work in this situation?
  • Jlabs
    Ah now I see why you suggested making it a separate part originally. I'll try that, thanks!
